Totti
Feb 20, 2014Aspirant
Wake On Lan with R7000
Hi, i get my new R7000 today and have an Asus RT-N66U before. The Asus WOL work fine but i found no way to use WOL with the R7000. With the R7000 i cant use 255.255.255.255 as Subnetmask to use ...
- Aug 10, 2015
Hi Riker.
Now that I've confirmed that the removal of my solution was a moderation, I'll try repeating it from memory (I was actually using this thread, bookmarked, to remember how to do it).
- Download TelnetEnable from here: https://github.com/LuKePicci/NetgearTelnetEnable/blob/master/binaries/windows/telnetenable.exe?raw=true
- Open a DoS/Command Prompt on a PC directly connected to the same LAN and type 'telnetenable.exe <router-IP> <router-MAC> admin <admin-password>'
- Telnet to the router
- Type 'arp -i br0 -s x.x.x.x mm:mm:mm:mm:mm:mm' where x.x.x.x is the WoL destination IP address (not .255) and mm... is
the WoL destination's MAC address
You should then have a static ARP entry in your router. Set up forwarding of port 9/UDP to your device you want to wake and it should work.
- Dave
ViperGeek
Aug 10, 2015Apprentice
Mods,
Was my solution removed on purpose, or did a forum update perhaps wipe out my formatted text by mistake?
- Dave
Babylon5
Aug 10, 2015NETGEAR Employee Retired
ViperGeek, I can see several posts made by you in this thread, and none deleted, so are you referring to a solution within this thread or another thread?
- ViperGeekAug 10, 2015Apprentice
Babylon5 wrote:ViperGeek, I can see several posts made by you in this thread, and none deleted, so are you referring to a solution within this thread or another thread?
Thanks for the response, Andy. My posts survived, but some of the juicy content was removed. For example, Message 25 had detailed steps for using TelnetEnable and creating static ARP entries, and Message 32 had possible solutions for another customer's problems that were seemingly removed. Finally, another user's quote of my original solution in Message 35 was converted to "...".
I'm OK with the edits if they were purposeful. It's just unfortunate that the most effective, viable solution was removed from this forum thread.
- Dave
- Babylon5Aug 10, 2015NETGEAR Employee Retired
Dave,
I can see that those posts are clearly truncated, but even though these forums allow limited editing now, an edited post is tagged as ‘Edited’. I can only assume that text was lost in the transfer, but it seems too selective. Short of me asking everyone capable of such edits, we will have to wait and see if someone has an answer, but my guess is that no one had an issue with what you had posted.
- KennethLAug 10, 2015NETGEAR Employee Retired
Babylon5 wrote:
Dave,
The original postings used [List] .. [/List] ie. numbered listing,. appears to be lost in transfer. Original postings have been updated with original content.
Kenneth
