tedio's avatar
tedio
Tutor
Sep 14, 2018
Where can I change the user name admin?
  • > [...] I don't see how to add a user to use instead of admin. [...]
       Netgear doesn't provide a way to do that.
    > [...] I am concerned with security. [...]
       Ok.  Please explain how a different user name would improve security
    more than using a longer password.
  • > Model: R6700v2|Nighthawk AC1750 Smart WiFi Router
       Is that accurate?  Firmware version?
       Perhaps on some other router, or with some future firmware version on
    your router?
       If you think that using a different user name for the administrator
    account would improve security, them you might consider adding your
    proposed alternative user name to your current "admin" password.
    • tedio's avatar
      tedio
      Tutor
      The firmware is V1.0.2.60_10.0.44, The hardware is R6700v3. I am concerned with security. I don't see how to add a user to use instead of admin.
