fractaloon
May 26, 2022Follower
Where is the time zone setting on Nighthawk X4S R7800
I was trying to change my timezone and couldn't find the setting.. Everything I read said it is in Advanced tab under Security -> Schedule. It wasn't there and I found another post saying as much but no solution as to were to find it. I looked through all the menus and eventually stumbled across it in...
Advanced tab under Administration -> NTP Settings
It can depend on the firmware installed on the device.
Things have moved over time.
So if that doesn't work, check your firmware version.
- KitsapMaster
