clinton113's avatar
clinton113
Follower
Apr 27, 2023
Which router is better TP-Link AX3000 or NetGear NightHawk AC1900?
I’m mainly looking for best range at 5Ghz speeds it’s a big house, especially for gaming and streaming ethernet not applicable. Please help me to choose best option for my house. Thanks in advance
    • microchip8's avatar
      microchip8
      Master
      You cannot really compare an AX router to an AC one.
      Also, AXxxx and ACxxx are speeds, not router model numbers.
      • michaelkenward's avatar
        michaelkenward
        And you might not get much feedback about TP-Link hardware in a Netgear group.
  • plemans's avatar
    How big is the home?
    What actual tp-link router is it? AX3000 is a speed.
    Whats the interior walls made from?
    What's your budget? (that's key as well as its pointless to recommend a top end mesh/router if its not in budget)
    You might be better to go with a  mesh system depending on the size of the home.
