diane72's avatar
diane72
Why did WiFi name change?
I want to know why my WiFi name would change? All of a sudden our internet wasn't working. I couldn't find our WiFi NETGEAR04 it was gone. I followed instructions online and connected a computer to the Ethernet and logged into the Network. It now shows my WiFi as NETGEAR - 5G with no password protection. How could this happen? Did someone hack our home network? I think I can easily reconfigure, but I want to know why this happen or if I am missing something else? Thanks, Diane
  • It has the same end result. It allows you to manage the device from a central place (router), rather than having to set up a static IP in the device, as well as making sure the router doesn't hand it out to another device.
    Most devices by default use DHCP (or in simple terms, get IP address automatically).
  • plemans's avatar
    A coupe ideas that could have caused it.
    1. people have reports of occasions where a reboot causes a router to reset.
    2. Maybe it reset after a firmware update if it was automated.
    What I'd do if you're concerned about someone getting in and changing settings around would be to reset it back to factory, reconfigure it for your settings, change the default login password, and make sure you put a wifi password on it.
    https://www.netgear.com/support/product/R7900P.aspx
    • diane72's avatar
      diane72
      The odd thing is that the NETGEAR04 is the name it came with. If the reboot caused it to change it's name where did this name come from? I also had a password on it to begin with. I could do a reset back to Factory, but is this difficult to do? I set it up, so perhaps it isn't that tough.
      • plemans's avatar
        Resetting back to factory is pretty easy. We always recommend a reset back to factory anytime someone does a firmware update so its a good time to check if you're firmware is current.
        To reset, just hold the reset button on the back for 7-10 seconds until the lights change.
        the link I had in my last post has your firmware, installation guide, and a manual there.
