JasonWise's avatar
Feb 01, 2020
Why do I have to reboot my R7000 everyday?
I recently purchase this router and was SUPER excited about it. At first, everything was GREAT! Zero complaints. Recently though, it has started acting up. I literally have to reboot the router 1-2 times a day. I've gone through all the options and found nothing out of the ordinary. Not sure if it's due to Comcast or not, but it just annoying as hell to hop on the computer to then reaslise that I have to go and power cycle the router everyday.
  • Usually not, but if you encounter any issues, a factory reset and reconfigure from scratch is recommended
  • which firmware version? The only current recommended firmware that is the most trouble-free is .42. Anything above is a mess
  • Oh and some more details.
    ISP: Comcast
    Modem: Arris SurfBoard Docsis 3.1 SB8200
    Router: R7000
    Issues: I have to reboot daily because at some point I will not be able to browse any websites, my wireless will drop and the devices I use on wireless won't see ther SSID period. Now what's odd as hell is that dispite not being able to connect to the wireless or surifng sites, I can load up World of Warcraft just fine.
