Busta999
May 22, 2016Aspirant
Why is QOS assigning a Low Priority to Speakers/Media Players?
I have AirPlay Speakers set up around the house and bizzarly NightHawk is assigning these with a LOW QOS setting? The speakers keep dropping out despite an 87% Signal Strength at 54Mbps another o...
- Jun 03, 2016
Fixed it
everything works great now
returned the NetGear to Amazon bought an Asus
aalexandrebeta
Jun 03, 2016Master
well QoS is something strange when I put low on a device it can suck all my bandwidth, I complained a lot with that stuff!
Back to your business you should update your FW, then you can see what happen.
you did config advanced setup / Admin/ Connected devices/Edit attached device and assign priority and did nothing, there is nothing more you can do until they redesign the QoS feature.
Complain more!
Retired_Member
Jun 03, 2016Netgear QOS is HOSED leave it off.
- Busta999Jun 03, 2016Aspirant
Fixed it
- aalexandrebetaJun 04, 2016Master
OK see you in 3 years for the R1300
