ricko2001's avatar
ricko2001
Wifi AP using PoE
I'm installing an ethernet cable in my home in a hallway and want to put an WiFi AP there. No mains power available.
It seems only business models use PoE.
Any recommendations?
  • plemans's avatar
    May 01, 2021
    You can use business class equipment in a home. They will sell it to you.
    I'd only make sure to keep an eye out for those that require a subscription for certain capabilities.
    • ricko2001's avatar
      ricko2001
      Those are all n the "Business" section.
      Will netgear sell one to me for home use?
      (I am retired SW developer, so I should be able to figure it out)
      • plemans's avatar
