tandilero's avatar
Mar 29, 2022
WIFI Button Nighthawk X10 (AD7200)
I need to know if there is anyway to set wifi on/off button to disable guest network only. That way the admin people can continue to use internet while easily turning off guest access without using the interface, just simply pushing the on/off button
  • Not the button, but you don't have to use the graphical user interface (GUI).
    genie | Product | Support | NETGEAR
    The Netgear genie for your operating system can do it. So can the Nighthawk app.
    Not as simple as pressing a button, but easier than firing up a browser.
    The app can even do it remotely.
