Rkedonnay's avatar
Oct 20, 2020
WIFI Devices Issues
All devices are showing wifi adapter issues. When connected with ethernet connection, no problems.  Have used Nighthawk to verify update of latest version of firmware.  Any suggestion?  Does this indicated router replacement?
  • plemans's avatar
    Oct 21, 2020
    1 & 2  So by adding multiple devices to the 5ghz band, is it reasonable to move a printer and an iPhone to the 5ghz band and leave the laptop and desktop with second channel? These are all my devices. ---Printers take mininal data. It'd be fine on the 2.4ghz. the desktop/laptop/streamers should be on the 5ghz.
    3 & 4 Your advice has given me a good reason to give the factory reset a try. I don't really want to purchase if this one still has good life remaining. After factory reset, am I correct in that this would be similar to a new installation?----It should I will need to do the reset today around 3 p.m (EST) and hope it's completed by 6 p.m. Zoom conference.  If this a reasonable time frame?  -----Maybe? Depends on your capabilities. If its a job sensitive call, i might hold off until afterwards. Its usually takes me 5-10 minutes but I do this weekly/monthly because I swap devices so much.
    You advice is so helpful. Thank you so very much.
  • plemans's avatar
    What modem do you have?
    Firmware on the router? (not the latest, the number)
    What "adapter issues" are you having? Does it not connect? Does it connect but say no internet"
    does it connect and say internet but it doesn't work?
    What exactly is going on? We need details since we aren't there to see whats actually happening.
    • Rkedonnay's avatar
      Rkedonnay
      Tutor
      plemans My modem is Netgear Nighthawk CM1200 (9/2019 purchase date)
      Router firmware number V1.0.1.6.2.1.0.4.1
      Adapter issues have been sporadic for past few months; disconnect ; connect with no internet.
      FYI I have attributed these issues to my HP laptop adpater but all diagnositcs on HP showed no hardware or driver issues. Now, have these sportic issues with Dell desktop all in one, and smart tv streaming issues.  Speed test indicate very fast, excellent, etc.
      Screen print attached of Netgear Genie data page.
      Thank you for your response
      • plemans's avatar
        Have you noticed if there's a difference when connected to the 2.4ghz or 5ghz? or do they both have sporadic issues?
        Also, do wired devices have issues or only wireless?
        When was the last time the R6400 was factory reset and reinstall? Sometimes old settings can cause issues (from firmware changes) and a full factory reset and reinstall can be beneficial.
