Mozer92's avatar
Mozer92
WiFi drops when downloading large files
I have firmware version 1.0.11.110-10.2.100.
When DL large files my WiFi shuts off and turns back on.  I have already done a factory reset of this router.
  • plemans's avatar
    Have you tried the recommended firmware for the router?
    A quick search on the forums shows issues with the R7000 firmware.
    the agreed upon stable/decent version is 1.0.9.42
    I'd recommend installing it over a hardwired connection, factory reset afterwards, and then do a clean install (not from backup).
    • Mozer92's avatar
      Mozer92
      So install the stable firmware and then do a hardware reset?
      • plemans's avatar
        correct.
        And make sure to do a clean install. Meaning don't use a backup configuration. If an old setting is causing issues, reinstalling a backup just puts that setting back in there.
