Robert-sk-2017's avatar
Jul 30, 2017
Wifi Router R6900 - disable WPS
Dear Community, I dont undestant about disable WPS functiuon. On support netgear is written that when I clear PIN code it means disable WPS, but on manuals is written that when is PIN clear, device automaticly creat SSDI an KEY. Pleas how it function and haw I permanently disable WPS. Thanks
  • Hi Robert-sk-2017,
    Clearing or unchecking the Enable router's PIN will disable the WPS connection via the PIN but still WPS is working if you use the WPS button.
    WPS via the button will only work if the device you are trying to connect uses a WPS button as well.
    There is no option to fully disable the WPS.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi Robert-sk-2017,
    • JamesGL's avatar
      JamesGL
      Hi Robert-sk-2017,
      We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
