Krit21's avatar
Krit21
Tutor
Dec 30, 2021
WIFI Speed not as fast as the SPeedTest results
Hi All,  I need some help.....i have tested the speed at the router and have almost 300Mbps.
I connect my iphone Xr to the wifi and ran a fast.com test and only get 12Mbps.
i have researched alot of topics, restated the router and home network, changed the wifi channels...no improvment.
any help would be grateful....thank you
  • plemans's avatar
    Are you using smart connect?
    What band are you connecting to?
    If you hardwire a pc/laptop into the router, what speeds do you get?
    What modem/gateway is the router connected to?
    What firmware is on the router?
    • Krit21's avatar
      Krit21
      Tutor
      Are you using smart connect?          Yes, single wifi name
      What band are you connecting to?             6,44,157
      If you hardwire a pc/laptop into the router, what speeds do you get?   340 Mbps avg
      What modem/gateway is the router connected to?   armstong cable modem, not sure of name
      What firmware is on the router?     V1.0.4.76_10.1.82
      this is a recent speed issue, within the last 4 months.
