Dtrain84's avatar
Dtrain84
Wired devices cannot connect to the internet
If I try to connect a device to the router via ethernet cable, whether it be a laptop or another device, I cannot connect to the internet using that wired device.
The Nighthawk app lists the wired device in the 'Device Manager' section, and shows a connection with a green light.
Any suggestions?
  • plemans's avatar
    What modem do you have?
    what firmware is on the router?
  • Yes, tried all of that. Issue still present. Incredibly frustrating. Perhaps the router is faulty?
    • michaelkenward's avatar
      michaelkenward
      Be warned, the message before your reply was linkspam, with a bit of random text related to not much.
      You would do better to answer the questions from plemans. Without that information, it is hard to diagnose what is happening.
      You might also like to investigate the network settings in Windows, and use the Network Troubleshooter.
      • Dtrain84's avatar
        Dtrain84
        Sorry!
        Modem is a Netcomm ndd-0300 FTTC.
        Router firmware is V1.2.1.22.
