StanH's avatar
StanH
Tutor
Jun 24, 2021
With Nighthawk R7000 connected USB to printer, how can I print from Android phone over WIFI?
My Nighthawk R7000 is connected USB to the printer. How can I print from my Android phone over WIFI?
Printer: Brother MFC8860DN
Phone: Google Pixel 2 XL
Android: vesion 11
  • Have you tried installing the Brother iPrint&Scan application from the Google Play Store on your phone?
    • StanH's avatar
      StanH
      Tutor
      Brother iPrint&Scan can't locate the printer.
      • Kitsap's avatar
        Kitsap
        Master
        Have you downloaded the manual and read chapter 11 on sharing a USB printer?
        Sharing a USB printer requires use of the Netgear ReadySHARE utility for computers.  Not the smoothest approach to sharing a printer on the network.
        You may not have a path to print from a phone without a network capable printer.
  • > My Nighthawk R7000 is connected USB to the printer. [...]
       Doesn't the "N" in that model number stand for "Network"?  If the
    printer has its own network capability, then why would you use a USB
    connection to a router with Netgear-quality print-server software?
    > [...] How can I print from my Android phone over WIFI?
       How do you use _any_ networked printer from an Android device?
