Borthalomew
Dec 29, 2017Guide
[X10 (R9000)] cannot regenerate or invalidate VPN credentials
I'm shocked I spent so much on a high end router, and I'm stuck with the static OpenVPN configuration on the router. There is no way to invalidate old keys, generate new keys, or have multiple active...
- Dec 30, 2017They need to address this across their product lines. A fixed key is a problem. Plus it is signed with MD5 and should be SHA2 now.
Borthalomew
Dec 30, 2017Guide
Yes I know about dd-wrt. This is a complaint regarding Netgear's supported firmware. The design is insecure.
I may go to dd-wrt, but was only going to do that if there are critical features I need. Several hardware features are not supported by dd-wrt, and it is not officially supported by Netgear. Additionally if there are two hardware versions as you indicate, dd-wrt may have less support from the open source community (fewer users per version).
Jessegodsey
Dec 30, 2017Star
Well, one supports Plex while the other does not. But yes, I am with you. I am still running stock.
