Borthalomew
Dec 29, 2017Guide
[X10 (R9000)] cannot regenerate or invalidate VPN credentials
I'm shocked I spent so much on a high end router, and I'm stuck with the static OpenVPN configuration on the router. There is no way to invalidate old keys, generate new keys, or have multiple active...
- Dec 30, 2017They need to address this across their product lines. A fixed key is a problem. Plus it is signed with MD5 and should be SHA2 now.
Jessegodsey
Dec 30, 2017Star
Yes, I am aware of all of those including 5g issues as well, but this was not a discussion of who knows what and so on, but more of making sure you knew what other options you had available to you.
juched
Dec 30, 2017Apprentice
- JessegodseyDec 30, 2017Star
Agreed, you obviously either work around IT Security or are in the IT field as well :-)
- juchedDec 31, 2017ApprenticeASUSWRT Merlin build by Vortex for R7000 is a very slick firmware. Seems asus has their act together. And yes, you control the VPN key.
Did read their QoS wasn’t working, but unsure if that is still true.
