frekin's avatar
frekin
X10 R9000 wired network running at 100Mbps
I recently bought a X10 R9000 router to replace my old WNDR4500 N900 router, also from Netgear. I have Cat 6 or better ethernet cable running from the cable modem to the router and from the router to...
  • ElaineM's avatar
    ElaineM
    Sep 01, 2017
    Try to reflash the firmware and do a hard reset.
    If it didn't work, I suggest that you exchange it for a new one.
    1. With the unit powered on, press and hold the reset button on the back of unit for 30seconds.
    2. Without releasing the reset button, unplug the unit and hold reset for another 30 seconds.
    3. Power on the unit while STILL pushing the reset button and count for another 30 seconds before letting it go.
