Juanlanas13's avatar
Juanlanas13
X10 slow speeds over wireless
I just a netgear nighthawk x10. Wired i have 200 mb wired i have 20. Can you please help. My modem is a cm600. Thank you.
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    Welcome to the community, Juanlanas13
    Just to verify, what's the wireless speed you're getting on your wireless?
    What's the wireless adapter being used on your wireless device?
    What are the wireless clients? Are they laptops, mobile phones, tablets?
    Did you try changing channel on the router?
    Which signal are you connecting (2.4GHz or 5GHz)?
    Make sure to avoid other wireless devices that may interfere with the wireless connection.
    See the link below for more information.
    Improving 2.4Ghz Wireless Performance by Changing Channel
  • My wireless speeds are 17 mb on my lg v20. 20 on my labtop with ac wireless. Ive tryed changing the channel serval times with no luck. I enabled wmm and it went up to 50 mb but a day later it went back to 17 mb. Wired i have 280 mb.
    • ElaineM's avatar
      ElaineM
      Try to factory reset the router and observe your connection.
      By the way, factory reset will wipe out all the settings so I suggest that you reconfigure it from scratch.
    • ElaineM's avatar
      ElaineM
      That's great news!
      Thank you for the update and have a great day!
