mrmagloo
Apr 13, 2017Apprentice
X4 R7500v2 New Firmware Rolls back QoS???
In the last couple of weeks I hit the firmware update button to check for anything new, and it installed 1.0.3.10. I thought cool. Then I went over to QoS and checked for an update there. It was running an update dated June 2016 - I did not however catch the version number. It downloaded an update and after, I checked, and the new version is dated April 2015. What the heck? I keep trying to update, but no joy.
I did read some old thread about bad keys in the firmware causing problems with past QoS updates, so all I can guess is perhaps the new firmware had a problem too?
Can one of you mods check into this please? I have no idea how to recover the previous 6/16 QoS version.
Thanks
I just checked and it will update to June 2016. Thank you! Noting that this update is nearly a year old, can you say if this will update again, and what is the normal frequency? Thanks Elaine.
- mrmaglooApprentice
Here is the version it rolled back to:
Version: v2.0421.cloud-ga Release Date: April 21, 2015 It will not allow me to go forward to the previous version I had from June 2016. Even then, that was 10 Months old. Does this QoS database ever get updated on a regular basis?
Please advise.
