TBy's avatar
TBy
Tutor
Jul 08, 2018
X4S File copied over the network fail MD5 checksum and are corrupted
 I have the X4S configured as an access point. I have a PC connected to the X4S via ethernet cable. Files copied over the network consistently fail MD5 checksum. I've searched and found a related post with no resolution, other than configuring the router as a normal router and not as an AP which is not a fix but a workaround and I need the AP configuration.  Link to previous thread
I'm running the latest firmware v1.0.1.52.
I replaced the router and all files copied are without error, so it is definitely a problem with the router. Very frustrated as I'm having to go back and restore backups due to the corrupted files but not everything was backed up.
  • by the way for a test you just need to disconnect you cable from internet port and to attach it to the internet port. two seconds. and i beat you will not have such md5sum problems anymore.
    you have to use the only lan ports if your router is in ap mode. no wan port. i guess you are using wan so it is a reason.
    • TBy's avatar
      TBy
      Tutor
       The manual states to connect the X4S Internet port to the LAN port of the other router which is how it is/was configured. I take it the "Internet" port is what you reference by "WAN" port. Is there reference that your method should work?
      • Kitsap's avatar
        Kitsap
        Master
        Maybe the error is in the manual.  Would it be reasonable to use the second configuration and run a test?
