vitus
Jan 01, 2021Aspirant
X8 R8500 + EX8000 or Orbi AX6000? Which is best?
I currently have an X8 R8500 but we still have some dead/weak spots in the house so I have a few questions for those more familiar with Netgear.
Will the EX8000 work with my X8 R8500 to extend? How about the EAX80?
Would it be better to get the Orbi AX6000? What would I gain or lose between the Orbi AX6000 vs the X8 + EX8000? How about the EAX80 instead of the EX8000?
I am always up for upgrading but the Orbi price tag is a bit steep. At the same time, I'm concerned about losing some usability with the consequences of the backhaul using the R8500 + EX8000 set up. I'm guessing that one of the 3 bands gets taken up for backhaul tasks. The EAX80 is listed as dual band so it seems it would be even more impacted. I know I could run CAT 6 for the backhaul but that wont be an option for a while and may not be an option for some areas.
I have read up on these mesh systems and extenders a bit but I'm just not sure how these in particular would work together and how it would compare to the Orbi AX6000. If keeping the R8500 and extending off of it with one of those extenders didn't cause a reduction in services and I'm not missing much by not taking the opportunity to upgrade to the AX6000 I would consider keeping it. If the AX6000 was enough pure improvement, I would consider it.
Your thoughts, opinions, and education are greatly appreciated.
Try plugging your needs into the filters on the product pages:
Wireless Routers for Home | NETGEAR
WiFi Range Extenders: Boost Your WiFi Range | NETGEAR
and
Orbi: Whole Home WiFi System for Better WiFi Everywhere | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
- vitusAspirant
Thanks for those links. I'm more wishing there was a comparison tool to compare what my R8500 has to what is available now. The R8500 is a great router, I really like it and I'd hate to accidentally downgrade features and functionality. I dont know if the Orbi firmware features are less, better, or equal to the R8500.
- JFIIGuide
vitus wrote:Thanks for those links. I'm more wishing there was a comparison tool to compare what my R8500 has to what is available now. The R8500 is a great router, I really like it and I'd hate to accidentally downgrade features and functionality. I dont know if the Orbi firmware features are less, better, or equal to the R8500.
Wouldnt it be nice if this got updated...
https://www.netgear.com/images/NG_WirelessRouterComparisonGuide24Sept1318-44305.pdf
