NUKLRSOLDR
Dec 14, 2014Guide
Xbox one best settings?
Bottom line up front: I am in search of the settings that provide the best online experience specifically for Advanced Warfare (single xbox setup). I.E. provide the lowest latency experience. No I...
- Nov 07, 2015So with Black ops 3 coming out I wanted to make sure I was going to get the best experience that I could.
I did a lot of sole searching and research made the changes and did a proper reboot. So far my online experience is awesome and is like night and day compared to playing advanced warfare. I'm not sure if Black Ops 3 is the only reason or not but I will detail below what is currently working great for me.
On my modem (standard Xfinity modem/router with the 90/15 gb plan) I turned off the firewall completely and set to bridge mode. Then plugged my router into it. For the modem settings for me it was 10.0.0.1 and default username and password (admin and I can't remember PW but you can google it if you have Comcast.
On the nighthawk.
I updated the firmware.
Updated my time zone in the security menu.
Changed the DHCP reservation range to a max of .100
Setup Xbox with a reserved ip (static ip) of .150 (well outside the range of the reserved ips)
Setup port forwarding to the Xbox with
TCP: 80
UDP: 88, 500, 3544, 4500
Both: 53, 3074-3075, 3076, 1863, 16000
I left upnp on
Disabled SIP and set to open
Turned on upstream qos and used the built in speed test to set upload bandwidth.
Edited all default rules with a highest priority and changed to a high priority.
Changed the default Xbox priority from high to highest.
And set up a custom rule to my Xbox MAC address with highest priority.
On the Xbox:
I turned off Kinect and DVR
Left network ip settings to get automatically
But set dns manually (I use 8.8.8.8 and 8.8.4.4)
On my TV:
Game mode on
All reductions and motion smoothing off.
If you have the option choose refresh rate as close to 60 hz as possible
Proper reboot after all settings changed:
Unplug router
Then unplug modem
Then fully turn off Xbox (hold power button until it turns off)
Wait 1 minute then turn on Xbox
After Xbox is on wait at least 5 minutes before plugging in modem.
Wait for modem to fully turn on
Then plug in router and wait for it to fully turn on
Once Xbox connects to XBL go to network settings and run multiplayer test. After test hold all triggers and bumpers until the next screen pops up.
Some of this may not matter but it's what I did and knock on wood I continue to have an amazing experience as I have had so far with black ops 3.
NUKLRSOLDR
Nov 19, 2015Guide
Being the perfectionist that I am, even though my previous settings worked really well. I have found more ways to improve my Black Ops 3 experience. It now feels as though I am cheating and perhaps I am because most people don't have this setup.
With port forwarding I deleted the 53 and 80 (my logs showed interesting activity)
I added the following: tcp and udp: 77, 3330, 2869, 10243, 10280-10284
Udp only: 1900
With reserved ip addresses I added every device that connects to my router to have an assigned address far from the Xbox (device 1 .101/ device 2 .102/ etc./ Xbox .200)
With qos I ran an upload speed test on test my.net and choose the 100 mb option. I got 9.5 previously I was getting 12 or so from speedtest.net. I set my qos upload bandwidth at 9.
Also I deleted all of the default rules and setup custom rules for each device on my network using the MAC address option. Giving Xbox highest priority and everything else normal priority.
I replaced the Comcast modem with the Motorola surfboard sb6183.
In wan settings check the box to enable respond to ping on Internet port.
If you are lucky enough to get IPv6 like I now do. Set that up under advanced settings. For me auto configure worked. Near the bottom with the two radial buttons don't use auto select the use dhcp option.
Also setup the Google IPv6 dns servers here.
If you run a test through the settings on the Xbox you should still see your .200 IP address instead of an IPv6 IP address but the dns servers should be the Google IPv6 ones.
To fully test go to the edge browser on the Xbox one and go to an IPv6 test website (Comcast has one) after that test you should get 10/10 and it should show your IP address as a IPv6 address in the browser.
Also go and setup the IPv4 dmz servers as googles IPv4 servers. (8.8.8.8)
You can turn the wifi off on the router if no one is using it by holding the wifi button on the router. This will make the router not have to work so hard if no one is using wifi.
Cables ensure all cables are tight. I recommend upgrading them if you have the cash (cat6).
Xbox: plug directly into wall outlet (this is explained by Microsoft as important) not a power strip.
I noticed recently that there is an option in settings where you can set 60 hz refresh rate It was on by default for me but I disabled allow the 50 hz and other lower hz options.
I also adjusted some other things that my tv could support like the color depth to 36.
I also turned off smart glass connections.
I just upgraded my day one edition to the new elite bundle. OMG it is crazy. I used to load into matches and the timer would be between 2 - 10 sec until the round starts. Sometimes the match had already begun. Now every time I'm the first person in and the clock is 14 - 16 sec. Every time! Not sure if it's the Xbox contributed but after about 4 hrs playing online with the new console I have yet to have any lag that can't be explained by other people's connections.
Udp only: 1900
- alex-devineNov 19, 2015Aspirant
Hi,
I found this post while browsing Google Search, some days i have amazing games and other days it just seems to lag a lot. I am currently working my way though your guide NUKLRSOLDR.
I did some tweaks last night before going to a football match and i plan to continue this evening. I would like to thank you for taking your own time to document your tweaks and fixes.
I will report back soon, thanks again :)
