Miniomar
Nov 08, 2020Follower
Attacco ransom su nas readynas 102
Ciao a tutti ieri ho ricevuto un attacco informatico con ransom mars che ha criptato quasi tutti i file del mio NAS readynas102 intanto chiedo info se qualcuno sa se c'è un modo di recuperare i ...
- Nov 08, 2020
If you use snapshots, those may allow you to recover the files from before the encryption. I say "may" because in the process of encrypting, the files would have needed a lot of new space and snapshots may have been deleted in the process to make room. As for actual decryption, not a chance.
Obviously, the best solution would be a factory default and restoration from backup, but I'm assuming you would not have asked if that was an option. This is but one reason RAID is not enough to keep your data safe.
Antivirus on the NAS likely would not have stopped it and certainly can't fix it. Assuming you have kept the OS of your NAS up to date, the files were likely encrypted by a virus running on a PC that leaves an SMB connection open with a mapped drive, not by something executing on the NAS. It's that PC that needs better protection, not the NAS.
Even before you get access to the files, you need to find which PC was the path for the encryption virus and fix that. When you do get access, backup is your best insurance. I use (and I believe StephenB does as well) a backup NAS on a power schedule that has only rsync protocol enabled. That makes it much more difficult for a virus to find the files on the NAS. But there is still the issue that the backup NAS will back up the encrypted files and my delete snapshots if there is not enough free space. So, if you can stop that backup process between when the virus hit and the next backup, that's ideal.
Not leaving a connection open to the NAS when it's not really needed and not using the PC password on the NAS or storing the NAS password in the PC's Windows Credentials Manager can also be a partial solution for some, but it's not foolproof. Only using an account with the minimum access rights (so never admin) for normal file access can also help. If you do have any ports open to the outside world, then strong passwords are also key.
Sandshark
Nov 08, 2020Sensei
Migliora le tue competenze con la Netgear Academy - Formati, certificati e rimani aggiornato con la tecnologia Netgear più recente!
Unisciti a noi!
ProSupport for Business
Piani di supporto completi per l'ottimizzazione della tua rete e la tranquillità della tua azienda.
