DJPeterPiper's avatar
DJPeterPiper
Follower
Dec 14, 2025
2.4 GHz Band Stops Working
I am having the same issue as described by nquintero. It is occurring overnight and only affects 2.4 GHz devices.
Router Firmware Version V1.0.5.22
ISP Modem/ONT: AT&T BGW320-505 with IP Passthrough (DHCPS-Fixed) to the BE9300
Cable: CAT5E shielded between modem and router
Protection Engine: ON
IPv6: Disabled
Smart Connect: Enabled
2.4 GHz: Auto channel
5 GHz: Auto channel
Access Control is ON
I do see these.
DoS Attack: RST Scan from source: 52.223.17.52, port 443
DoS Attack: RST Scan from source: 34.211.134.21, port 443
It has been solid for several months since install but just this week began to drop my connections to my wifi lighting devices in the middle of the night. I do not stream televisions, those are hard wired. The 5 GHz and wired devices remain connected. The only recovery is a power cycle.
