noink
Oct 12, 2025Aspirant
Allow way to disable 6hz or implement MLO
I own the RS 600 and it is completely unusable in my basement office. My phone always connects to the 6hz network. It shows a strong connection, but my teams calls always end up dropping. Yes, I coul...
CrimpOn
Oct 13, 2025Guru - Experienced User
noink wrote:completely unusable in my basement office
Is this perhaps an exaggeration?
- Pixel 9 works with a wired connection
- Pixel 5 works because it connects to 5GHz
- In an "office" I would expect to find some sort of computer that could do Teams meetings
Are Teams meetings the only things that fail with the Pixel 9 when connected at 6GHz?
- noinkOct 13, 2025Aspirant
No. Taking teams calls on my phone makes all kinds of good sense, it allows me to walk around the house. Plugging pixel 9 into a wired connection is called trouble shooting, it allows for narrowing down the problem. You can plug any phone into a cat5 cable via a USB dongle. What would be my motivation for exaggerating?
