noink
Oct 12, 2025Aspirant
Allow way to disable 6hz or implement MLO
I own the RS 600 and it is completely unusable in my basement office. My phone always connects to the 6hz network. It shows a strong connection, but my teams calls always end up dropping. Yes, I coul...
CrimpOn
Oct 13, 2025Guru - Experienced User
noink wrote:completely unusable in my basement office
Is this perhaps an exaggeration?
- Pixel 9 works with a wired connection
- Pixel 5 works because it connects to 5GHz
- In an "office" I would expect to find some sort of computer that could do Teams meetings
Are Teams meetings the only things that fail with the Pixel 9 when connected at 6GHz?
noink
Oct 13, 2025Aspirant
No. Taking teams calls on my phone makes all kinds of good sense, it allows me to walk around the house. Plugging pixel 9 into a wired connection is called trouble shooting, it allows for narrowing down the problem. You can plug any phone into a cat5 cable via a USB dongle. What would be my motivation for exaggerating?
