noink
Oct 12, 2025Aspirant
Allow way to disable 6hz or implement MLO
I own the RS 600 and it is completely unusable in my basement office. My phone always connects to the 6hz network. It shows a strong connection, but my teams calls always end up dropping. Yes, I coul...
CrimpOn
Oct 13, 2025Guru - Experienced User
Completely unusable sort of implies "it doesn't work at all (in the office). Not good for anything." Would it be correct that as long as the Pixel 9 remains in the office that Teams calls work correctly and it is only when the phone moves around the house that there are problems? i.e. it might be the movement and perhaps the 6GHz signal falling that causes problems?
