noink
Oct 12, 2025Aspirant
Allow way to disable 6hz or implement MLO
I own the RS 600 and it is completely unusable in my basement office. My phone always connects to the 6hz network. It shows a strong connection, but my teams calls always end up dropping. Yes, I coul...
noink
Oct 13, 2025Aspirant
No. Taking teams calls on my phone makes all kinds of good sense, it allows me to walk around the house. Plugging pixel 9 into a wired connection is called trouble shooting, it allows for narrowing down the problem. You can plug any phone into a cat5 cable via a USB dongle. What would be my motivation for exaggerating?
Oct 13, 2025Guru - Experienced User
Other users have posted that having Protection Engine enable has causes problems for them and disabling it seems to help resolve it.
Disabling PE would be a troubleshooting step to help narrow down the issue.
Also basements are not good places for host routers. All that concrete and steel surrounding will inhibit good signal travel. Main level or 2nd level is preferred locations for the main host router.
