wheedoggee
Aug 20, 2025Tutor
BE (RS) series sending out BPDU on WAN
I am a network admin and have seen the same BPDU issue cited in this link (below). It is coming from multiple make/model BExxxx RSxx / RSxxx series Netgear routers. I would like to know what firmware...
- Aug 21, 2025
Hi,
I just sent you a private message. Looking forward to your reply.
rahul2gupta
Aug 26, 2025Aspirant
Hi I'm also facing a similar issue where BPDU is being sent out when trying to connect it to a switch. I'm using the RS300, any chance there's frimware or settings that solve it?
- wheedoggeeAug 28, 2025Tutor
this is what they told me for the resolution for the improper BPDU broadcast, however you will have to ask for the trial link directly from netgear. i do not have that:
Here’s the current status by product family:
RS700 — Not impacted.
RS600 / RS500 / RS200 — Fixed in FW V1.0.5.12 (official release).
RS300 / RS150 / RS180 / RS140 / RS130 — Fixed but not yet officially released. Netgear can provide you with a trial version if you’d like.
RS100 / RS90 / RS70 — Fixed in FW V1.1.1.94 (official release).- rahul2guptaSep 02, 2025Aspirant
Thank you! I ended up updating firmware to latest and it started working for some reason. Maybe they released it already?
- FURRYe38Sep 02, 2025Guru - Experienced User
What version of FW was loaded on your router?
