wheedoggee
Aug 20, 2025Tutor
BE (RS) series sending out BPDU on WAN
 I am a network admin and have seen the same BPDU issue cited in this link (below). It is coming from multiple make/model BExxxx RSxx / RSxxx series Netgear routers. I would like to know what firmware...
- Aug 21, 2025
Hi,
I just sent you a private message. Looking forward to your reply.
rahul2gupta
Aug 26, 2025Aspirant
Hi I'm also facing a similar issue where BPDU is being sent out when trying to connect it to a switch. I'm using the RS300, any chance there's frimware or settings that solve it?
wheedoggee
Aug 28, 2025Tutor
this is what they told me for the resolution for the improper BPDU broadcast, however you will have to ask for the trial link directly from netgear. i do not have that:
Here’s the current status by product family:
 RS700 — Not impacted.
 RS600 / RS500 / RS200 — Fixed in FW V1.0.5.12 (official release).
 RS300 / RS150 / RS180 / RS140 / RS130 — Fixed but not yet officially released. Netgear can provide you with a trial version if you’d like.
 RS100 / RS90 / RS70 — Fixed in FW V1.1.1.94 (official release).
- rahul2guptaSep 02, 2025Aspirant
Thank you! I ended up updating firmware to latest and it started working for some reason. Maybe they released it already?
- FURRYe38Sep 02, 2025Guru - Experienced User
What version of FW was loaded on your router?
I don't remember the version number prior to updating, sorry :(
