alray1989's avatar
alray1989
BE9300 - Cannot connect any device
 MY Samsung Q60 TV, Fire tablet, Ring doorbell, Amazon Echo.  None will connect.
Previous NIghthawk router I had no problem.  Have rebooted everything.  Tried to enter IP manually.
Still wiil not connect.
Thanks for any advice.
  • FURRYe38's avatar
    Use same SSID name and password and prior router?
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    • alray1989's avatar
      alray1989
      Thank you for your attention to my problem.  I  contacted Netgear support.  The issue has been resolved.
      • FURRYe38's avatar
        Please share with us how the issues was resolved so others can know if they see this issue.
  • CrimpOn's avatar
    CrimpOn
    The web interface allows the user to control many features which the 'app' does not.  Use a device with a screen larger than a smartphone (computer, laptop, tablet). Connect it to the RS300 router with Ethernet or WiFi, and follow the directions on page 71 to log into the router and set the Security level to WPA2-Personal.  Even though the default setting of WPA2 and WPA3 is supposed to be compatible with almost every device, there are some devices that simply balk at connecting when WPA3 is enabled at all.  Just click the appropriate box on the screen. and then "Apply" at the top of the page.
  • Sorry I am only slightly above a novice on these issues.  I looked on the router label.  Did not see anything related to security level.
    Used the app - does not show anything about security.  Did not understand anything on page 71 of manual.  I assume that
    it is the default level when installed .. I would not know how to change it.
