ilian007
Dec 08, 2025Aspirant
Can I use MS80 Satellite with RS280 router ?
Hello, I wonder if I can use MS80 Satellite with my RS280 Router ? I know there is newer MS90 WiFi 7 that is compatible. However, I want to use MS80 is compatible as cheaper option. Thank ...
- Dec 08, 2025
No.
MS can only connect to there perpective model MR units:
Nighthawk MK Series MESH System Compatibility Information | NETGEAR Communities
ilian007
Thank you for the quick response to everyone! If you know, can you tell me what do I need to get to extend my RS280 coverage ? I prefer extender with Ethernet cable.
