Dummy001's avatar
Jul 08, 2026
Fun with lights.
So, except for my printer (white HP) my desktop theme (I have 2 Dells, 9020 and a 790 - Hey, if it's not broke, don't fix it. They work awesome) Anyways, my theme is Black with Blue lights....except for this new RS100. Well, I have fix this. You need 3 things. Some velcro, a DR. Teals bath soap (I've attached a picture) and a SHARP knife.
I'm sure the picture does this justice BUT if not, I trimmed down one side of the bottle, put velcro on the top and bottom and new, well, my lights on the RS100 are blue!!
I know, stupid BUT I like it.
  • FURRYe38's avatar
    Seems like you wanted to change the color of the LED output?
    Not sure if that model has LED adjustments on the routers web page. Maybe all ON or power only ON if you don't wanna LEDs to all be on.
    Some can use post it notes to cover the front if needed.
    Not sure what DR is.
    • StephenB's avatar
      "Dr. Teals bath soap"  Just an extra capital...
      Creative!
      Keep in mind that the LEDs have two colors - amber and white.  The improvised filter might make it hard to distinguish them.
      • Dummy001's avatar
        Dummy001
        Tutor
        I believe the amber light is the top one. Only amber when it's powering on or rebooting. And yes, creative...thanks! I had originally thought of cutting the bottom of the bottle off and slipping it over the router. They appear to be the same size. But then I thought of a lack of ventilation...heat is electronics enemy. This was the next best thing.
