nteambx's avatar
nteambx
Having issues with connecting to the internet on 10G port from ISP: Optimum
Having issues with connecting to the internet on 10G port from ISP: Optimum. The 10G port is in bridge mode where it is suppose to give a public ip. The router is not able to get a lease from DHCP. The port works when connecting directly to pc. RS700 isn't able to dynamically fetch from the DHCP for some reason. Tried turning off firewalls, noticed some DDOS false positives on 68 port.
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed?
    Turn off and unplug modem.
    Plug in and turn on modem. Wait 1-2 minute for it to connect.
    Turn on computers and rest of network.
    Be sure the ISP doesn't have any specific WAN side configurations that maybe needed. Ask them about this. Some require PPPoE configurations.
    Check for any MAX Spoofing as well.
    • nteambx's avatar
      nteambx
      Altice Gateway 6 Max, xsr150dx, Optimum. Using cat8 wire.
      Tried all those steps already.
      There is no login required, I am able  to get internet when directly connected to laptop. ISP turned on bridge mode.
      Also tried spoofing mac of link on laptop.
      • FURRYe38's avatar
        Is the cable STP or UTP cable? STP being preferred here.
        Does the RS show a connection on the RS web page under Advanced tab/Show Stats button?
        Can you post a screen capture of this page?
        Wondering if the ISP could put the gateway back in router mode and then use the router DMZ for the RS700...
