cofresi59
Mar 03, 2026Aspirant
Having Problems with OpenVPN for Mac
I recently upgraded my ASUS router to a Netgear RS700. I configured the OpenVPN service to TUN mode on UDP port 12973 and TAP mode on 12974. Clients will use VPN to connect to the internet and the home network. I also configured a DDNS service with no IP. My Mac's IP address is static. I tried TunnelBlick, and it seems to connect. I've never used Tunnelblick before, but I see a pop-up showing some sort of communication between the server and the client. When I use OpenVPN, it just refuses to connect. I downloaded the smartphone configuration file, and it still doesn't connect. Did I miss anything? Any ports that need to be forwarded that I missed? I desperately need help because I help my wife with her college courses remotely. Now that I have a new router, I need OpenVPN to work. She is out of state and not very computer-savvy, and can't get her to install Tunnelblick or add the configuration file. Any help will be greatly appreciated.
- cofresi59Aspirant
Hi again,
I opened the config file with Text Edit, and this is what I found:
client
dev tun
proto udp
remote xxxxxxxx.mynetgear.com 12973
resolv-retry infinite
nobind
persist-key
persist-tun
cipher AES-128-CBC
comp-lzo
verb 5
dhcp-option DNS 68.94.156.11
dhcp-option DNS 68.94.157.11
I noticed that the DNS is different from the DNS I use, which is 1.1.1.1 and 1.0.0.1. Would that make a difference?
cofresi59 wrote:
dev tun
proto udp
remote xxxxxxxx.mynetgear.com 12973Interesting. Your config file is using TUN. The file I posted (using TAP) is the Mac config file from my Orbi 870.
Changing to TAP is worth a try - just save the original file, so you can put it back if needed.
The DNS servers in the config file are hosted by AT&T. It should be fine to change them to Cloudflare. If that still fails, then you could also try just removing those lines.
- cofresi59Aspirant
I forgot to mention that my WAN IP address is public, which is the same IP that AT&T gave me when I set up their router. I cloned the MAC address of the AT&T router and I am able to get internet through the Netgear RS700.
- cofresi59Aspirant
Thank you for replying. I haven't configured my Mac for TUN and TAP. Would you be kind enough to show me how to do it?
Open Client.conf. You should see something like this:
client
dev tap
proto udp
remote xxxxxxxx.mynetgear.com 12974
nobind
persist-key
persist-tun
ca ca.crt
cert client.crt
key client.key
cipher AES-128-CBC
comp-lzo
verb 5
script-security 2
up dhcp-client-request.sh
To switch to tun, change dev tap to dev tun, and 12974 to 12973.
So not in one of the ranges I listed above?
Have you tried both TUN and TAP configurations on the Mac? It's fairly easy to modify the config file to change that.
Only if you are double-routing. Is your RS700 WAN IP address a private address?
- 10.0.0.0 – 10.255.255.255 (10.0.0.0/8)
- 172.16.0.0 – 172.31.255.255 (172.16.0.0/12)
- 192.168.0.0 – 192.168.255.255
- 100.64.0.0. - 100.64.127.255 (100.64.0.0/10)
