Bodoque's avatar
Bodoque
How to find BE9300 Tri band wifi router IMEI?
I'm trying to find the IMEI number that's associated with my router I don't see it on the router itself, on the app or when I log in to Netgear as an admin. Does anybody know where to find the IMEI if this router comes with one?
  • FURRYe38's avatar
    NG routers do not have a IMEI number. Only cell phones do.
    • Bodoque's avatar
      Bodoque
      So if I want to check if the BE9300 router is compatible with Verizon business wifi you are saying I can't check if it's compatible since the router doesn't have an IMEI to input when prompted by Verizon to put one in?
      • ShadowMario3's avatar
        ShadowMario3
        Luminary
        If the internet you're looking into requires a SIM card (mobile internet), you'll need a hotspot like the Netgear Nighthawk M6/Pro. If the internet you're looking into doesn't require a SIM card, you do not need an IMEI number whatsoever.
