Rjmer739
Nov 29, 2025Follower
i noticed that my ipv4 lease expires at 47000+ days and it causes my internet to crash
I'm having a similar issue. I noticed when going into the router settings Advanced > Advanced home > Connection Status i noticed that my ipv4 lease expires at 47000+ days and it causes my internet to crash. I sometimes have luck in using the Renew button provided to have the internet recover but, sometimes i have to full unplug the router to regain internet. I had my ISP check it out just incase and they believe it might be an issue with the latest firmware with the router. I'm currently using the RS700
I had exactly the same problem as you describe. See the link below.
It was fixed with a trial firmware.
- ckamAspirant
I am facing the same issue since few days ago, assuming the ISP is the one causing the problem until I saw your thread posted in Nov.
Since the thread is locked after you marked the issue has resolved, shd I open a new thread about the problem or else ?- FURRYe38Guru - Experienced User
What model# is your router?
- WarmHelp_NTGRNETGEAR Expert
Hi Rjmer739
I have sent you a private message. Please kindly check it when you have a moment.
