JDGamer's avatar
JDGamer
I'm not savvy enough to know what "bufferbloat" is
I'm not savvy enough to know what "bufferbloat" is, but I have been having a HORRIBLE time gaming with this router. I have Frontier Fiber FiOS at 2 gigabit speed, and have to literally reboot the router mid-sessions almost EVERY time I play an online game like ARC Raiders, Fortnite, Helldivers 2 or other multiplayer online game.
I'm using a PS5 Pro plugged directly into an ethernet port on the router (no wireless ever) using a top-end 3ft cable from Infinite Cable, have set up on the PS5 Pro to use the CloudFlare DNS on the PS5's advanced network settings, assigned the PS5 a pre-set IP address and put that IP address in for the DMZ, turned off QoS, IPv6, and still am having network-wide crashes where every device - including things like family iOS devices - losing access to things like Facebook and YouTube which - again - requires a full router restart.
I have the latest publicly available version of the firmware as well and it has not helped any.
This is insane that a $600 router is this unreliable.
  • Current firmware version on my RS700
    V1.0.10.8_2.0.109
    Mfr / model # of ONT :
    XGS-PON ONT Model FRX523
    The cable is from Infinite Cable - a quality manufacturer of all things cable :
    https://us.infinitecables.com/products/cat8-s-ftp-40g-shielded-patch-cable-24awg-riser-cmr?variant=43920869556537
    No IPv6 is Disabled...
    ...and Protection Engine is Disabled as well.
    I haven't checked the Netgear admin webpage for my router when the network crashes. It usually happens at a VERY in-opportune time where I want it back online as soon as possible, so I use the iOS Nighthawk app to reboot the router. Up until the point I do the reboot step, I am still seeing the network name. During the reboot process the network temporarily disappears until it finishes the reboot at which point everything resumes functioning when reboot is complete.
    I bought the router through B&H Photo in mid-June of 2025
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    Is IPv6 enabled on the router?
    Is Protection engine enabled on the router?
    I have my RS700 online since early this month. Game on xbox and have not seen any of these issues to date. Though I'm on cable with a NG CM3000 cable modem. 1Gb ISP service. IPv6 disabled on my router. PE enabled on the router.
  • Also, I forgot to mention I have a 5-port 10GB TP-Link un-managed switch set up for my >1Gb ethernet port devices like my main desktop PC (and an 8 port 1Gb unmanaged switch for the wired devices throughout the rest of my house, including my Synology NAS), but again - the PS5 Pro is plugged directly in to the router itself.
