JDGamer's avatar
JDGamer
I'm not savvy enough to know what "bufferbloat" is
I'm not savvy enough to know what "bufferbloat" is, but I have been having a HORRIBLE time gaming with this router. I have Frontier Fiber FiOS at 2 gigabit speed, and have to literally reboot the router mid-sessions almost EVERY time I play an online game like ARC Raiders, Fortnite, Helldivers 2 or other multiplayer online game.
I'm using a PS5 Pro plugged directly into an ethernet port on the router (no wireless ever) using a top-end 3ft cable from Infinite Cable, have set up on the PS5 Pro to use the CloudFlare DNS on the PS5's advanced network settings, assigned the PS5 a pre-set IP address and put that IP address in for the DMZ, turned off QoS, IPv6, and still am having network-wide crashes where every device - including things like family iOS devices - losing access to things like Facebook and YouTube which - again - requires a full router restart.
I have the latest publicly available version of the firmware as well and it has not helped any.
This is insane that a $600 router is this unreliable.
  • I am looking online at my chat records w/ friends and I first started seeming to notice the issue mid-November and started trying to troubleshoot it (but whatever I did seemed to not fix the issue fully each time, as it would come back and require a full reboot).
  • Still having issues - now even in games that I never had problems with before that don’t seem like they should need much network traffic… like Elden Ring, or pulling up leaderboards on Astro Bot. Both having disconnects.
    What the hell, Netgear?!
    • FURRYe38's avatar
      Been using my RS700 with Division 2 gaming and haven't see any issues. Most issues seen were with the gaming services.
      These games work if you directly connect the console to the ONT?
      Is the RS 700 using detected ISP DNS or are you using custom DNS? Cloudfare or Quad 9?
      Had a power OFF of the ONT and RS router for 1 minute then back on been performed?
      Checking speeds thru the RS router to speed with a ethernet connected PC and ooklas installable speed test app?
  • Update : finally reached out to ISP and went up in support tier. At first they said “things looked fine” on their end, but I elaborated how it seemed to ONLY have issues during gaming where the entire network would crash (router admin page was still accessible but internet across all devices was usually down for a bit right after online multiplayer gaming round of any kind would start). That seemed to get them to actually check the logs…
    And so it looks like the culprit is probably faulty ONT hardware (tech said diagnostic had shown 50+ disconnects just in the past 2 days). They are coming out to replace and swap out older cat5e run from ONT to router inside the house tomorrow afternoon, so we will see if that fixes things.
    • FURRYe38's avatar
      Thanks for the update. Glad they seem to be proactive on this. Let us know how it goes.
      You might get a CAT6A STP cable in between the ONT and your RS700. What I use with mine.
