Freaky
Jul 04, 2026Initiate
IOT device fails to communicate to cloud
Subject: RS280 Protection Engine Blocks Beatbot AquaSense 2 Pro Cloud Registration Router Information Model: NETGEAR Nighthawk RS280 Firmware: V1.2.7.2 Internet Configuration AT&T BGW320-505 ...
Aurion64
Jul 08, 2026Aspirant
Having some issue with Protection Engine on a RS200, cannot get my Tesla Powerwall 2 (2.4Mhz only on this item) to join my network, if I disable "Protection Engine" it can join, so something new in last firmware, running current V1.2.7.2
Jul 09, 2026Guru - Experienced User
Something to contact NG support about and let them know. PE maybe blocking too much and may need to be tuned in.
Aurion64 wrote:Having some issue with Protection Engine on a RS200, cannot get my Tesla Powerwall 2 (2.4Mhz only on this item) to join my network, if I disable "Protection Engine" it can join, so something new in last firmware, running current V1.2.7.2
- Aurion64Jul 09, 2026Aspirant
Thanks for the update there a section in router that has IOT, can I add Telsa Powerwall there, I will raise a support to let NG know.
Do you know this IOT section?
- FURRYe38Jul 09, 2026Guru - Experienced User
Maybe under Basic/Wireless Settings tab on the RS web page or under Advanced Tab/Advanced/Advanced Wireless.
