Freaky
Jul 04, 2026Initiate
IOT device fails to communicate to cloud
Subject: RS280 Protection Engine Blocks Beatbot AquaSense 2 Pro Cloud Registration Router Information Model: NETGEAR Nighthawk RS280 Firmware: V1.2.7.2 Internet Configuration AT&T BGW320-505 ...
Jul 10, 2026Guru - Experienced User
So your using Guest Network for your device now?
The IoT network and setting a WPA2 only mode didn't work?
What printer model is this? Does it have ethernet port by chance? if so, try ethernet connecting printer?
Aurion64
Jul 10, 2026Aspirant
So your using Guest Network for your OLD devices now? Yes work fine. i.e Fronuis Inverter, and Telsa Powerwall 2.
The IoT network and setting a WPA2 only mode didn't work? Yes do not work.
But my problem now has nothing do with NG gear.
My Workforce 60 printer which has 10/100 port is stuck on wrong port via wireless which I cannot see, I've try with "Epson Net config port software" but cannot see this printer via wireless, would connecting it to the 10/100 port might help you think?
