notmywookiee's avatar
notmywookiee
Follower
Jun 07, 2025
Just upgraded to fios 1gb. RS700 wifi uploads are like 50 to 120 mb/s
so having what appears to be same issue.  just upgraded to fios 1gb.   RS700 wifi uploads are like 50 to 120 mb/s . had an old orbi rbk50 around and it gets max wire speeds and consistent up down on wifi in hundreds of mb/s.   figured maybe it is something in the 10gb port comms with older ont so tried setting wan aggregration and putting wan in the port 4 wan aggregation port.  That worked somewhat and uploads doubled in speed but still lagging behind the orbi rbk50 speeds by about half.
1 Reply
  • FURRYe38's avatar
    Who is the ISP?
    What brand and model# is the ONT the RS router is connected too?
    Be sure your using good quality LAN cable between the ONT and RS router. CAT6A STP is recommended.
