olegeezer's avatar
May 20, 2025
MLO and RS700S router
Have any of you been able to get MLO installed on the RS700S router? I am still waiting for netgear to release MLO for the RS700S router. Let me know if MLO is available yet.
Thanks, Matt
  • FURRYe38's avatar
    You don't install MLO. MLO is a FW feature of the router and wifi devices that have MLO features encoded into there HW and FW. Ya, Still waiting on MLO support for the RS series.
  • I would be surprised if MLO is even coming in 2025...
    • FURRYe38's avatar
      Only half way thru the year. Anything is possible. Ya, still asking about it.
  • CrimpOn's avatar
    CrimpOn
    What test would a person perform to determine whether MLO is present on a WiFi7 router?
    • FURRYe38's avatar
      Having a supporing MLO BE supporing wifi adapter.
      On Orbi BE systems the BE supporting wifi device would be seen connecting at the router on WiFi using both 5+6Ghz status on the routers web page. Currently only showing a single connection, SLO, either 5Ghz or 6Ghz.
      How to verify Wifi 7 from Orbi RBE971 | NETGEAR Communities
      Also seen in Windows 11 wifi status, windows reports both 5Ghz and 6Ghz connection if MLO is present.
