Landyman's avatar
Landyman
Need to set-up an RS500 with a Modem
Hi, I am having a dry run in order to set-up the Modem to see if it works before I move cables and install my RS500. As part of the Modem install I have to fix the ip address of my PC to 192.168.1.1    I have followed all the advice given on Google as to how I configure the IP on the PC and it all changes ok visually but as soon as I try to close the properties page the internet connection is lost and windows troubleshooter immediately returns the PC config to where it was. I cannot find any reference to this happening in the google world I'm afraid so I wondered if any one here has had this problem and can help me. The PC / Network is currently handled by my Netgear D6400 which I understand is no longer supported.  Can you help me please?  Thanks
