JC0928's avatar
JC0928
Nighthawk RS500 Setup Issue
Hello - I just received my Nighthawk RS500 router and am trying to set it up. I have fiber internet with an existing ethernet cable that I'm using.....every time I try to set up the router via the app, it gets to the part where it checks the ethernet connection and it errors out saying to make sure the ethernet cable is plugged in, which it is.....I can't get past this step in the process. Any suggestions? Thanks
  • plemans's avatar
    What ONT do you have?
    You can also go through the browser based setup and manually input the settings for your isp/
    • JC0928's avatar
      JC0928
      It is a Calix. I tried doing the manual set up but it wasn't allowing me to log in to the admin page to do it.
      • michaelkenward's avatar
        michaelkenward
        That's a brand, not a model.
        It's like saying "it is a Netgear" or, "it is a Ford".
        What happened when you tried to login? What with? Any errors?
        Disclaimer: Just another user with time on their hands.
    michaelkenward
    Do it with a web browser and the graphical user interface (GUI).
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    That page will also have any software, firmware and drivers for your device, if they exist.
    Check the section in the manual Manually set up the Internet connection
    There may also be some helpful videos on what to do.
    You may have done that already. I can't tell from your message.
    I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
    • JC0928's avatar
      JC0928
      Yeah, after the app wouldn't allow me to connect, I was looking thru the online manual and started to to do the manual internet connecting process via web browser but the webpage you have to go to wouldn't allow me to log in.
        michaelkenward
        JC0928 wrote:
        ...started to to do the manual internet connecting process via web browser but the webpage you have to go to wouldn't allow me to log in.
        What browser? What message did is show?
        The devil is in the details.
