Bob_P_1959's avatar
Bob_P_1959
Follower
Feb 18, 2026
Nighthawk RS600 Dev list blank
I recently purchased a Nighthawk RS600. Everything seemed to work fine for a short time. Then the list of attached devices was blank. I restarted the router and that fixed the problem... for ONE DAY!
2 days ago, I updated my firmware to V1.0.6.16 and the device list was back. 2 days later, however, nothing. Is Netgear planning to put out a new FW to fix this problem? If so, when will it be available??
I can't keep re-starting the router only to have it fail the next day. And a factory reset is out of the question. I'd be setting up the router from scratch on a daily basis. That is NOT a solution.
Considering the cost of this router, it shouldn't be plagued by something as trivial as this.
If anyone has a real fix for this issue, please let me know. Otherwise, I guess I'll just have to wait for Netgear to put out a new FW which will hopefully include a fix for this problem.
Thanks.
  • CrimpOn's avatar
    CrimpOn
    Please confirm, is this
    • The list of devices on the web interface?
    • The list of devices in the Nighthawk app?
    • Both of them?
    Thanks
  • plemans's avatar
    I have the RS600 and I've never ran into this issue.
    What modem/gateway is it connected to?
    Have you tried a factory reset after running into these issues?
