Yonisi
Mar 19, 2025Aspirant
Nighthawk RS90 Router - I need very specific technical information
Hi,
I ordered a Nighthawk RS90 Router through Amazon and the product reached the local custom office about a week ago. The custom office is asking me to fill a special form in order to pass the government communication office check. I tried by my forms were all rejected for not having enough information.
My question is:
Is there a way to get specific details about the product? I couldn't find such information even on the official documentation. The information needed is:
1. The exact frequency ranges used by the Router, for both the 2.4 and 5GHz bands.
2. The max power output of the Router.
Is there a way to find such information anywhere?
Thank you for any help,
Yoni
Can you confirm this model #? RS90 doesn't seem valid.
There is RS### model numbers.
- YonisiAspirant
Sure here is the link to the product's page:
https://www.netgear.com/support/product/rs90/
Can look up what specs are for 2.4 and 5Ghz on a online search as these would be for both frequencies seen on any wifi router system.
Power requirements varies and is mostly kept at the mfr level.
- YonisiAspirant
Is there a way to tell the 5GHz frequency that is associated with each of the 802.11 type?
I mean the n/ax/be etc? Is it even relevant to talk about those with regards to frequencies? I tried to find a table/explanation between the different types of 802.11 protocol and to frequencies used by each, but I only found this on Wiki:
https://en.wikipedia.org/wiki/List_of_WLAN_channels- FURRYe38Guru - Experienced User
The modes all use same frequencies.
