JLMcNeal
Aug 25, 2026Aspirant
No Internet to WiFi connected Items
Nighthawk BE9300. Is connected to the internet & WiFi transmitting but no internet connection to connected items,
I have powered down with no effect. 2.5G hard wired connection has no issue. No idea where to go from here.
Brand and model# of ISP Modem the router is connected too?
IPv6 enabled on the router?
What connected items are connecting to the router?
Channels used on the router for WiFi? Try 1 and 40 or 11 and 48?
I have powered down with no effect. 2.5G hard wired connection has no issue. No idea where to go from here.Is this a new setup?
If it is, then you could try phone support. In addition is the WAN cable connected to to the yellow ethernet socket?
If a client connected to the 2.5G LAN port works ok, then a problem with DNS is ruled out. This needs to be a wifi issue of some kind. What wifi settings (if any) did you change when you did the setup? In partcular, did you set up MAC access controls?
Any progress on this?
I have powered down with no effect. 2.5G hard wired connection has no issue. No idea where to go from here.- JLMcNealAspirant
For some reason it just started working again. No clue what changed
Interesting.
