JLMcNeal's avatar
JLMcNeal
Follower
Aug 25, 2026
No Internet to WiFi connected Items
Nighthawk BE9300. Is connected to the internet & WiFi transmitting but no internet connection to connected items,
I have powered down with no effect. 2.5G hard wired connection has no issue. No idea where to go from here.
  • StephenB's avatar
    Is this a new setup?
    If it is, then you could try phone support.  In addition is the WAN cable connected to to the yellow ethernet socket?
    If a client connected to the 2.5G LAN port works ok, then a problem with DNS is ruled out.  This needs to be a wifi issue of some kind.  What wifi settings (if any) did you change when you did the setup?  In partcular, did you set up MAC access controls?
  • FURRYe38's avatar
    Brand and model# of ISP Modem the router is connected too?
    IPv6 enabled on the router?
    What connected items are connecting to the router?
    Channels used on the router for WiFi? Try 1 and 40 or 11 and 48?
  • One "first step" is to open the web management interface and look at how Attached Devices describes connected devices.
    There is also a feature under the Security Menu on the Advanced Tab called Access Control.
